Hello, I have the right to add 3 widgets to the basic Instagram feed application I purchased, and 2 of them do not appear in my personnel account 1 widget. When I want to add, the account and hashtag application appears. I would appreciate your support on why it is not appearing in my 3rd widget.
Hi there, @RDK_Teknoloji ![]()
Do you mean that the settings for adding the source look different in your 3rd widget:
The thing is that the interface has been slightly changed and for new widget’s it’s like in the 1st screenshot.
If you want to choose a Personal Account type of connection, please follow these steps: Add Source - Account - Enter your username and click Search - Connect - Personal account:
However, if I misunderstood you, please describe the issue in more detail. I’ll be happy to check it ![]()
Hello,
I did it this way, but changes made via Instagram are not processed. There is no problem with my other 2 accounts.
