I need help with the comments
I made a post in the comments section, and when I reloaded the page, IT’S GONE! So how can the comments save? If my sister goes to my website and posts a comment, I don’t see it! Is there a fix?
Hi there and welcome aboard, @Matthew_Walker :waving_hand:
Could you please send me a link to the page, where your widget is installed? I’ll be happy to check it for you :slightly_smiling_face:
It’s at the top.
Is it not published yet? Here is what I see when trying to open the link:
How about this? https://sites.google.com/dekalbschoolsga.org/dekalbschoolsga-matthew/home?pli=1
If you try to comment, I won’t be able to see it. When I try to comment, you won’t see it. When I add something to the comments, I reload the page, and it disappears!
Can you send me a new embedded link that allows the comments to save?
I’ve discussed the issue with the devs. The widget isn’t working properly due to the specifics of Google Sites.
Please try reinstalling the widget using the share link, then send a test comment and let me know if it displays correctly on the page :slightly_smiling_face:
