Google reviews show in firefox on pc but not in chrome and edge
  • The google review widget does not show in chrome and edge on pc. In firefox I can see it and also in chrome on my smartphone.
  • Link to the page with the widget in question: https://www.fotograf.business/
Hello there, @Michael_Kleinespel :waving_hand:
I’ve checked your website in both browsers and the widget is displayed there on my end. Could you please try to check your website in incognito mode of the Chrome and Edge browsers and let me know if the widget showed up there?
If the issue still persists, please send me a screenshot of the Dev Console from both browsers :folded_hands:
Thanks for your help. It does not work in incognito mode in both broswers either.
Thanks! It seems to be a local issue. Please check your Internet connection and disable browser extensions/antivures/VPN and let me know if it helped :slightly_smiling_face:
You are right. I changed my wifi and the widget shows. Thanks for your help.
Awesome, you’re welcome :wink:
