Form won’t submit. Sends error msg
  • Issue description:
    Pasted a submission form on godaddy page. It won’t submit. Just keeps sending error messages.
  • **Link to the page with the widget in question:**Custom Request
Hey @Zackary_Milner ! :waving_hand:
Im testing your widget right now, ill give you a update :slight_smile:
Im back, @Zackary_Milner :slight_smile:
And you are right, theres actually a error massage :sweat_smile:
Maybe you can look at your GoDaddy Dashboard if theres a error, because sometimes GoDaddy pages can mess with the embed if there’s already a form tag on the page, or if something conflicts in the layout.
@Max can help with it! :slight_smile:
Thanks!
Thank you @maxim! I didn’t know dogs could work computers so well :face_with_hand_over_mouth:
I appreciate it.
Hah, thats funny :joy:
You are welcome :wink:
HI there, @Zackary_Milner and welcome to the Community :wave:
The thing is that the GoDaddy platform is built on iframes, which prevent reCAPTCHA in your form from working. If you disable reCAPTCHA, the form will work fine.
To fix this issue, please replace your current installation code with the new one and let me know if it helped :slightly_smiling_face:
<script src="https://custom-scripts.elfsightcdn.com/public-scripts/hostinger-and-go-daddy/install-widget.js" data-banner></script>
<div class="elfsight-app-7c402905-baac-4a44-8b87-37bd358813f8"></div>
Thanks @Max It’s works beautifully now!
It’s my pleasure :wink:
If anything else comes up, we’re always here to help!
