Events in multiple languages within the same calendar
Hello, our website where we embed the Event Calendar is bilingual English and French. I’ve created my events in English, but I don’t see an option to add a second language, short of creating a second calendar for the second language. What do you propose as the best solution?
Hi there and welcome to the Community, @user15828 :wave:
Unfortunately, it’s impossible to make the widget multilingual right in the settings. However, you can additionally use our Website Translator app for this purpose.
Just choose the needed languages and install the widget to your website. Please note that it will translate the whole page, not just the widget’s content.
Test it out and let me know if it worked for you :wink:
this is bad so we have to buy more?
Hi there, @Nik_Triffilos :waving_hand:
Yep, unfortunately, the multilanguage option isn’t supported in our apps. I am really sorry :pensive_face:
There are 2 possible solutions in this case:
  • Create separate Event Calendar widget for each language version.
  • Install our Website Translator widget to your website. So, it will translate all content on the page (including Event Calendar widget) to the needed language.
If you have any questions left, please let me know. I’ll be happy to help!
