Event location missing
Nothing more to say
Hello there, @user28972 :waving_hand:
Glad to say that you can add a list of locations in the Venues section on the Events tab:
Once the locations are added, you’ll be able to assign them to a specific event:
This option is not available. It goes to a default location, and I cannot edit it. Please assist.
Hi there and welcome to the Community, @Dr_English :waving_hand:
You can add more locations and edit them in the Venues section on the Events tab. I’ve tested your widget and everything is working fine:
Could you please double-check it and let me know if it’s fine now?
Hi Max! I appreciate your prompt reply, but I am unable to edit. Is there a video I can view? It does not allow me to edit. I may be in the wrong area.
Thank you,
Ebony
Does the video I’ve attached to my previous message show up on your end?
I saw the video, but I do not have that option. Here is my POV: https://www.loom.com/share/f67c860ff67b4c379f0a018c297d5d53
To make the other locations appear when assigning them to the event, you should add them to the Venues section on the Events tab first:
At the moment, you have only 1 venue (The Broad) added in the list. However, if you add more, they’ll appear when assigning the venues to events:
I can’t believe I missed this at the very bottom. I’m so happy I finally found it! Thank you! :slightly_smiling_face:
Great, you’re always welcome :wink:
