Would be great to be able to have the user know where the event is when they add it to their calendar.
Greetings and welcome aboard, @user19479 ![]()
If you add the set the venue for your event, it will be displayed for the users after adding the event to their calendar.
You can add the list of the venues in the Venues section on the Events tab:
After that, assign the needed venue to a specific event:
Check it out and let me know if it worked for you ![]()
