Share your use case and provide as many details to support your idea as possible. Thank you! ![]()
Each of my events is usually at a unique venue. I can of course add this to the descriptoin but I think it would be better if Venue/Location had its own field and can add a Google map location automatically based on the address.
Hi there and welcome to the Community, @Erik_Smith ![]()
You can add all the needed venues in the Venues section on the Events tab:
Once the venues are added, you can choose the needed venue for the event from the dropdown list:
This works great. Thank you. One suggestions is to add a field for phone number of the venue.
Nice idea, I’ve added it to the Wishlist on your behalf
- Phone Number field for the Venue
In the meantime, we’d like to invite you to participate in our new contest, where you can win a 6-month extension for your subscription - May Contest: Create a Caption for Our Photo and Win 6 Months FREE! ![]()
