Event Calendar: Change color of each widget element, font, size settings and more! 🚀
We’re happy to announce that the Event Calendar widget has received a set of new customization options!
You can now adjust more visual elements of your calendar, making it easier to match the widget with your website’s design :artist_palette:
What’s New?
The widget now comes with a new Theme section that includes 7 pre-designed themes.
If you’d like to create your own look, click Customize Theme to access additional settings for different widget elements:
Here’s what’s available now:
Widget Background
The calendar background can now be customized with different styles. Choose between a solid color, gradient, image, or video to match your website’s look:
Widget Title
The Widget Title settings now include more options for adjusting its appearance, including alignment, color, size, and style:
Filters & Search
This section lets you easily control filters & search color, color of the active filter and their font size:
Group
Group names are now easier to customize with options for changing their color, font size, and style:
Event
The Event section gives you more ways to personalize event cards, including background colors, corner radius, and other visual settings:
Pagination Buttons
Pagination buttons now have their own customization settings, including colors, text style, size, corner radius, and spacing:
Popup
Popup elements can be customized individually with options for colors, sizes, and corner radius:
Font
Choose the perfect font to align with your website’s style and enhance readability:
We hope these new options help you create a chatbot that truly reflects your brand. Let us know what you think — we’re eager to hear your feedback :blush:
Back to Changelog →
