Email Sender Setting (SMTP)
Hi Elfsight Team, and Community :sparkles:,
Happy New Year :partying_face:
It would be great if this widget had the “Email Sender Settings” so we could “Add Email Sender” similar to the other Elfsight Form Widgets (Contact From, Subscription From, and Form Builder). I think this feature should be standard, even for an MVP form. And, is even more important than sending an SMS reminder:
Also, equally important is being able to customize the notification email being sent. I’ve had to turn off sending the email notification (thank you for this feature). Luckily, this works for my client’s use case, as they prefer to carefully review each booking. So, I can use the “Success Message” to inform the user of that process.
However, I’d prefer in the very short term, for my client to be able to send customized booking confirmation emails from their own email address, rather than notifications@forms.elfsightmail.com.
Also, please check out all the Other Wishlist features I’m championing :gem_stone: , add your comments, and up vote them too :white_check_mark:
Thank you in advance :busts_in_silhouette::busts_in_silhouette::busts_in_silhouette: ……
Kind regards,
mw :man_technologist:t5: :sparkles:
Hi there, @iammasterweb :waving_hand:
This idea is already on the Wishlist, and you can upvote it here - Send notification from a custom domain.
Regarding an option to edit confirmation emails, we’ll keep tabs on this feature request and try to consider it, especially if it gets more traction :slightly_smiling_face:
