Display only greeting above launcher button (without suggested questions)
Id like the option to select just the chat button and greeting without the sample questions also included. When the bot opens it takes up the entire side of the screen covering up importan page info. Need a middle ground not just button or button plus greeting and samples.
Hey there and welcome to the Community, @Sean_O_Connell :waving_hand:
I agree that it would be great to have such an option right in the settings. If more users support this request, we’ll try to think it over down the line :slightly_smiling_face:
In the meantime, you can achieve this using the code below in the Custom CSS field on the Settings tab of your widget’s settings:
[class*="widget-welcome-window__QuickRepliesContainer"] {
  display:none!important;
