Discord Invite Widget
Discord has it’s own widget built into their software that you can use on sites but it posts all of the content from your community for others to see prior to joining. I would like a widget that essentially acts as an invite code link so people can click it and join the server.
Welcome to the Community @Night_Dweller :wave:
We have a Button app that might be a good option for your case.
Here you can set the required text, customize its appearance and add the invite link:
