Directory Project
Hi I’m looking to create a community business directory. Is there a widget close enough to begin this project. I attempted to use the event calendar widget but event would still be listed as a filter.
I’d like to be able to add businesses, their services and contact information on my website.
Hi @Jasmine_Gilliam welcome back :clap:
If that’s what you mean, then the suggestion already exists and you can vote for it.
Business Directory
Perhaps you should check out Team Showcase to see if it can be used for your “Businesses Showcase” project.
Thank you Sina!
Hey there, @Jasmine_Gilliam :wave:
I see that you’ve already set up the Team Showcase widget for your use case. If you have any questions or any assistance is needed, we’ll be delighted to help :slightly_smiling_face:
Hi I do have a question! I thought within my plan I have 3 projects and 9 widgets. Beside my team showcase widget it’s labeled for me to select a plan. Can someone help me understand the difference between apps, widgets and projects?
Hi @Jasmine_Gilliam
Here is an explanation of how to use projects.
Team Showcase is the app and you can create 9 widgets per app
@Jasmine_Gilliam, I’m sorry for the confusion!
To clarify, an “app” refers to a specific application, such as Event Calendar. The “widget” is a single instance of an app that you create in your dashboard.
At the moment, your Event Calendar single-app Pro plan allows you to create 9 widgets for Event Calendar only:
Project is a folder, where you can group your widgets. This, with your plan, you can create up to 3 such folders (projects).
If you’re also interested in using the Team Showcase widget, it would require a separate subscription.
You can either create a separate subscription for the Team Showcase widget or upgrade your subscription to the All Apps Pack plan.
If you want to use several apps, I suggest upgrading to a Pack plan - Upgrading to All Apps Pack from Single App. It will give you access to all Elfsight apps for the price of only 3!
Thank you for clarifying. What customer base would typically need the projects? Is it more so a preference for organization of the apps and widgets?
Nevermind Sina sent a link earlier. Thank you!
