Day Filter with a separate button for each (not a calendar view)
Hello,
I am using the Elfsight Event Calendar widget and would like to request the addition of two features:
  1. Day Filter: Users should be able to select a specific day, and only the events for that day should be displayed. (For example, selecting March 17 should show only events happening on that day.)
  2. Search Bar: Users should be able to search for an event by name or venue.
Would it be possible to add these features? If they are not currently supported, is there a plan to include them in the near future?
Best regards,
Mustafa Akan
Hi there, @MustafaAKAN :wave:
The Date filter is available in the widget:
As for the search bar, this idea is already on the Wishlist and you can upvote it here :slightly_smiling_face: - Search box
I would like it to be like the one shown in the picture above.
Got it, thanks!
Current;y, unfortunately, it’s impossible to customizae the widget this. If more users support this filter design, it might be considered in the future :slightly_smiling_face:
