Could Someone Guide me on How I can Optimize Widget Performance?
Hello there,
Please forgive me and provide kind assistance if I have posted to the wrong subsection.
I am currently working on a project that involves integrating several Elfsight widgets into a website. While the widgets are functioning as expected, I’m concerned about their impact on the site’s performance.
I have noticed that the widgets sometimes take a bit longer to load, especially on pages with multiple widgets. This delay can negatively affect the user experience and overall site performance. I’ve already optimized the website in terms of image sizes, server response times, and other common performance factors.
Also I have taken help from this: https://community.elfsight.com/t/reduce-widget-size/6026?page=2golang
I am reaching out to the community to see if anyone has tips or best practices for optimizing the performance of Elfsight widgets. Are there specific settings or configurations that can help reduce load times?
Are there any known issues or pitfalls to avoid when using multiple widgets on the same page?
I am open to any suggestions or advice you may have based on your experiences.
Thank you in advance for your help.
Hi @zach_tyson :wave:
Sure, I’ll gladly check things for you! Could you just send me a link to the page where your widgets are installed?
