add a Conversational Forms survey with multiple page image question with name and info and a contact form would be awsome.
@jj1 thanks a lot for your suggestion!
You know, we have a Survey template in our Form Builder widget, could it be a solution for you? It has a Multistep Form option, so you can easily customize it the way you need ![]()
