Booking review header not rendering properly
the Booking.com is showing as Booking.c in the header. i have reinstalled it a couple of times. it worked once and shows correctely on elfsight where i get the code. it just does not render on my web page.
I am worried about a bunch of hits on my webpage and my widget views being used up. i will post a screen shot.
Hi there, @Bryan :wave:
We’ve fixed the issue by adding this code to the Custom CSS field on the Style tab of your widget’s settings:
.es-source-image g {
  clip-path: none !important
Please check your website and let me know if it’s fine now :slightly_smiling_face:
Also, I’ve noticed that you’ve enabled the RTL mode, but the Reviews are in English:
Just in case, I’d like to remind you that you can disable it on the Layout tab:
yes! it is working great…Thanks so much
Great, you’re always welcome :slightly_smiling_face:
In the meantime, we’d like to remind about our Black Friday Giveaway, where you can win 1 FREE YEAR for any of your subscriptions :gift:
Check the details and join in - BF 2024 Giveaway: Win 1 YEAR of Free Usage (10 Winners) + guaranteed month!
