Is there a help topic that explains what happens if you use the “block domain” function on a widget?
Or if not, can you please explain?
If I select “block domain”, do the widgets stop loading, or stop working, on all sites on that domain?
Thanks.
Thanks.
That’s a very good question, Hugh!
Block Domain option can help you hide your widgets, i.e. they will stop displaying there.
You can find more info in our Help Center: Hiding a widget - Elfsight Help Center
Please let me know if you have other questions, I’ll be happy to help ![]()
Yeas i agree
