I need help adding the chatbot widget to weebly
so i made a weebly site and need to add it
Hi there, @user2544 and welcome aboard :wave:
We have a tutorial explain how to do this - Adding Elfsight widget to Weebly website - Elfsight Help Center
However, if any difficulties still come up, please request the installation in your dashboard and our Support Team will gladly assist :wink:
got it figured out, but it disappears when the user is using an ad blocker.
Yes, sometimes ad blockers can interfere with a widget’s performance due to one of these reasons:
1. The widget’s placement and the general structure of the page.
You can check whether the widget is being blocked separately from your website using this link - https://sandbox.elfsightcdn.com/WIDGET_ID. Just replace WIDGET_ID with the ID of your own widget, which is part of the installation code:
In case the widget is not being blocked at the link above, changing its placement in the structure of your website might help fix the issue.
2. Confusing a widget for an advertisement.
Unfortunately, this behaviour by your ad blocker doesn’t depend on us, and we can’t fix it on our side. I am really sorry :pensive_face:
Let me know if this explains things or if you have any questions left.
