The AI Chatbot won’t let someone submit their question if they are using an iPhone.
- Link to the page with the widget in question:
Hi there, @user3632 ![]()
Could you please send me a link to the page, where your widget is installed?
The issue occurs because of the Wix iframes. To fix it, the widget should be reinstalled avoiding iframes - Installing Elfsight widget on Wix avoiding iFrame - Elfsight Help Center.
If you face difficulties with it, please request the widget installation in your dashboard and our Support Team will gladly assist you with it. Do not forget to mention that the widget should be installed avoiding iframes ![]()
