AUDIO PLAYER - all tracks on playlist showing the same length
Hi, I am having issue with the audio player. In a playlist of several tracks of varying lengths, the list shows that tracks are all the same length, which they are not. The tracks play as they should but the track length is showing the wrong length:
e.g.: Into The Hill — DPJ
This is urgent so I really appreciate your assistance!
David
Solved folks. I realised it was a Safari browser issue.
Hey there @DpjMusic :wave:
Happy to hear that you’ve resolved the issue!
If anything else comes up, just drop us a line and we’ll gladly help :wink:
Actually it’s not resolved after all Max. On chrome everything works fine but in two playlists viewed via Safari on MacBook, iPhone etc, the timing info is still not correct. Every track in the playlist is showing the same length… what could this be?
Regards,
David
David Paul Jones
Composer, Pianist & Vocalist
e: info@davidpauljones.com
w: www.davidpauljones.com
m: 07919 274847
Could you please send a direct link to the page where your widgets are installed? I’ll be delighted to investigate it for you :slightly_smiling_face:
Max I have tried to reply with the info you requested but my emails are being rejected from your system
David Paul Jones
m: 07919 274847
Got you! I’ll contact you directly :slightly_smiling_face:
