hi, this app not working properly.. audio keeps cutting? and super slow.
Hi there and welcome to the Community, @user30867 ![]()
The playback issue you’re experiencing might be due to having too many tracks added to a single widget. Ideally, each widget should contain up to 50 tracks, and the total file size should stay under 5MB for smooth performance.
I hope this explains things.
If you’d like to keep all your current tracks in the widget, you can try disabling the Duration setting in the Playlist section of the Settings tab. This should improve the track loading speed ![]()
yes, unchecked the duration and now works properly, thanks.. ![]()
Perfect, you’re always welcome ![]()
