Issue description: We’re using the AI chatbot and have integrated and configured everything as intended. We’ve tested quite a few settings, but the chatbot on the website doesn’t have a border. In the preview, however, everything looks fine.
At first, we thought it was due to WordPress in conjunction with Elementor or WPRocket. But even when you embed the chatbot code directly into a completely blank, manually created page using , the border is still missing there. So there must be a problem with the Elfsight installation code itself, right? -
Link to the page with the widget in question: https://von-elbstein.de/
In the image on the left, you can see the chatbot—without the border.Below is a screenshot from the Elfsight preview showing what it should look like.
Hello there, @Sonke_Neise and welcome to the Community ![]()
I can see why this might be confusing, but the widget is actually working as expected on your website.
You’ve selected Quick Input Launcher as the style and Greetings & Suggested Questions as the Start Mode. With these settings, the widget initially displays an input field with suggested questions above it:
Once a visitor submits a question, the full chat window opens automatically.
In the configurator, however, the chat window is always open by default.This makes it easier to preview and customize the chat’s appearance and content.
If you close the chat window in the configurator, you’ll see the same input field and suggested questions as on your website:
If you’d prefer the full chat window to open right away on your website, simply select Open Chat Automatically as the Start Mode:
Please let me know if this clears things up or if you have any questions left ![]()
Ah, I actually just managed to get it to work similarly by chance. We actually wanted the chat with the predefined questions to be visible right away. That seems to be causing the problem. But if you select the speech bubble and predefined questions instead, the chat opens as it should—with a border and the predefined questions. We can live with that, but is that how it’s supposed to be?
As far as I see, the now the chat window is opened automatically on the page load. Do I get it right, that you’d like to implement the same behavior using the Quick input style?
If so, the Open Chat Automatically Start Mode is available for the Quick Input style too:
If I misunderstood you idea, could you please clarify what you mean under the frame and describe what you’d like to achieve in more detail ![]()
Actually, we wanted the chat to appear right away at startup with the preset questions. But when we set it to “Greeting & Suggested Question” plus the “Quick Input” field, it causes the display to be incorrect.
Now we have “Chat Opens Automatically” set to “Button.” You’ll see the speech bubble first, but when you click it, the chat opens with the preset questions. We can live with that.
For the Quick Input field this can be done using the Open Chat Automatically start mode:
The chat will show up on the page load with the list of suggested questions in the chat window. If you select “Greeting & Suggested Questions” as a start mode, the suggested questions will show up above the input field and the chat will be opened after sending your question (via nput field or when clicking the suggested question) ![]()
Ah, that’s it. Great, thanks so much for your help. But honestly, it is kind of confusing, because if you want to use the preset questions, you naturally assume you have to select the greeting and the questions. And the result really does look like something’s wrong—the questions just kind of fly across the chat.
But thanks so much for your help.
You’re very welcome, and thank you for sharing your feedback!
I can see how the Greeting & Suggested Questions option might be confusing, especially since you’d naturally expect to select it to display the suggested questions.
Just to clarify, the suggested questions will appear in the chat window by default as long as you’ve added them in the Suggested Questions section. There’s no need to select a specific Start Mode for that:
The Greeting & Suggested Questions Start Mode only controls how these elements appear before the chat window opens. With the Quick Input style, they’re displayed above the input field instead.
I hope this helps explain the distinction! And thanks again for pointing out the confusion — we’ll keep your feedback in mind as we work on improving the widget experience ![]()
Yeah, little confusing.
But now we understand. Thank you!
Happy to hear everything is sorted now ![]()
In the meantime, we’d like to invite you to join our contest, where you could win 3 FREE Months for your subscription.
Check the details and join in: October Contest: Add Your Twist to the Meme & Win 3 FREE Months!
Hi @Sonke_Neise,
I was perusing community posts this morning when I suddenly ran into yours. I noticed your AI chatbot setup is similar to ours and would benefit from the tip below. Once implemented, I am confident you’ll love the new look.
Cheers!
Thank you, I take a look.
