AI Chatbot: How to make form fields required for submissions
Looking for a way to make users fill in all fields in the AI Chatbot form before the submission? We’ve got a solution!
Just add this code to the Custom JS field on the Settings tab of your widget’s settings and you’ll be fine:
        if (element) {
            res(element);
            observer.disconnect();
(function makeInputRequired() {
  waitForElement("[class*='form-layout__Form-sc']").then((form) => {
    form.querySelectorAll('input').forEach(input => {
        input.required = true;
        input.setAttribute('aria-required', 'true');
    form.removeAttribute('novalidate');
This video demonstrates the feature in action:
Guys, was this solution helpful? Let us know in the comments :slightly_smiling_face:
Hi @Max,
For the community’s benefit, can you explain better what form fields are affected with your JS code? Also, can you post a screenshot depicting the affected form fields you are referring to?
Thank you :slight_smile:
As mentioned in the post, the code is applied to all form fields that can be added to the widget (Email, Phone, Name, Consent box).
However, that’s a great point that it would be better to show how the code works, and I’ve attached a video screencast with the feature in action to the original post.
Thank you so much for the feedback, we really appreciate that :blush:
