AI Chatbot: Connect to AI Assistants via MCP
You can now connect your AI Chatbot to MCP-compatible AI assistants and work with your chatbot data right from your favorite AI tools! :rocket:
With our new MCP server, you can explore conversations, check performance, review leads, and find ways to improve your chatbot just by asking your AI assistant.
Here are a few ways you can put the new MCP integration to use:
  • Explore conversations
    Search chats by keyword, topic, or date, and read full conversations.
  • Check your chatbot’s performance
    See how many conversations, messages, and leads you’ve received, and track trends over time.
  • Review your leads
    Find out who left their contact details and what they asked about.
  • Improve your chatbot’s knowledge
    Spot questions your chatbot couldn’t answer and add missing answers to its knowledge base.
How to get started
1. Connect your AI assistant
Add the Elfsight MCP server to an AI client that supports remote MCP connections and compatible authentication:
https://widget-data.service.elfsight.com/mcp/ai_chat
2. Sign in to Elfsight
Follow the authentication steps in your AI client and log in with your Elfsight account. No separate API key is needed.
3. Start exploring
Once connected, ask your AI assistant about your chatbot’s conversations, leads, or performance.
Check out our guide on GitHub for detailed setup instructions :raising_hands:
Have you managed to get everything connected? Which AI assistant did you use? And how’s it working for you so far?
Let us know in the comments — we’d love to hear about your experience :blush:
Back to Changelog →
Great news. Do you have any stores with this AI Chatbot activated? Maybe someone want to link their store? I am very close to activating it, but would like to see some websites with it activated first.. :slight_smile:
Hi there, @Stian_Sund and welcome to the Community :waving_hand:
Currently, the MCP connection in our AI Chatbot only works with AI assistants.
Would you like to connect the chatbot to your store via MCP, so it can fetch product information directly from your store and use it in its responses, or did you have a different use case in mind? :slightly_smiling_face:
Yes, that is correct. I would also like to see some demo stores with this AI Chatbot downloaded if possible?
fre. 16. okt. 2026 kl. 19:30 skrev Max <notifications@elfsight.discoursemail.com>:
Got it, thanks!
Unfortunately, this functionality isn’t supported at the moment. I am really sorry!
We already have some related ideas on the Wishlist and try to consider them down the line:
If you’d like to connect the widget to a different store, please specify your store and I’ll add it to the Wishlist :slightly_smiling_face:
Hi there,
good grief, this AI chatbot is really coming along nicely… I need to spend some time looking into it again. Why does a day only have 24 hours, and why do I need 6 of those for sleep? :hugs:
@Sina, 24 hours really aren’t enough when there’s so much to explore :grinning_face_with_smiling_eyes:
Hope you get some time to try it out soon!
