Adding Notification
It would be great for a notification to be sent when someone clicks “Submit”, letting them know their submission is complete and has been sent.
Hi there, @Kimberly_Morrison :waving_hand:
Glad to say that we have a form feature for this! You can enable it in the Results section settings:
If you click on Edit Form button, you’ll be able to set the needed form fields and add an email, where you’d like the notifications to be sent:
Thanks Max! I’ll check this out!!
I appreciate the follow up.
Kimberly Morrison
It’s my pleasure :wink:
