Accessibility widget doesn't seem to work
hi. i added the widget and it didn’t do anything. i see the icon, and when i open the icon it shows a score and some options…but when i click on the options it doesn’t adjust the site. i have been using AccessiBE for a few years now and thought i’d try this. Is this just a ‘score’ pop-up? or is it supposed to “adjust” the site like AccessiBE? if the latter, it is not working. Site is going live tonight so i’ll send the url tomorrow if you want to see it.
Here’s the url. Not working: https://www.inletmarinamotel.com I put the code in a Code Block on the home page. Was that correct?
Hi there, @user4847 :waving_hand:
Our devs have applied a local fix to your widget and everything is working fine now. Please check your website and let me know how it works :slightly_smiling_face:
Also, our devs are working on a global solution now. I’ll update you once the fix is released.
woot woot! thanks so much – it’s working great!!
Awesome, you’re always welcome!
By the way, we’d like to invite you to participate in our Birhday Contest, where you can win a 12-month extension for your subscription - Birthday Contest: 10 Winners, 10 Free Years with Elfsight! :wrapped_gift:
Great news - the issue has been fixed globally!
