Accessibility issue - text is clipped when resized
SiteImprove is flagging an issue with the LinkedIn widget when you increase the page size to 200%. We believe it only happens when there’s a LinkedIn post that’s text only, otherwise it only clips the image.
https://www.si.umich.edu/about-umsi/news
Hi there, @user33129 :waving_hand:
Unfortunately, I wasn’t able to catch this issue when checking your website using the Siteimprove (event with 200% zoom). Could you please send me a screenshot of the error you see?
Here is what Siteimprove is flagging as an issue:
When you view the page source there is a lot more text in the description, but it is being clipped/trimmed in the widget so that all of the text isn’t visible.
I’ve forwarded it to the devs and will update you once I have their response :slightly_smiling_face:
We’ve checked thing and it appears that Siteimprove is the only validator that identifies this issue.
Our devs suggested trying a custom solution. Please add this code to the Custom CSS field on the Style tab of your widget’s settings:
.es-text-shortener {
  line-height: 1.4 !important;
  position: relative !important;
.es-text-shortener[aria-expanded="false"] {
  max-height: calc(1.4em * 3) !important;
  overflow: hidden !important;
.es-text-shortener[aria-expanded="false"]::after {
  content: "";
  position: absolute;
  left: 0;
  right: 0;
  bottom: 0;
  height: 1.4em;
  background: linear-gradient(to bottom, transparent, #fff);
  pointer-events: none;
.es-text-shortener[aria-expanded="true"] {
  max-height: none !important;
  overflow: visible !important;
.es-text-shortener[aria-expanded="true"]::after {
  display: none !important;
And this script should be added to the Custom JS field on the Settings tab of your widget’s settings:
(function () {
  const ROOT_SELECTOR =
    "#eapps-linkedin-feed-1aafad70-0a37-492c-9f2e-ed9c95cb1fd0";
  function ensureIds(root) {
    const containers = root.querySelectorAll(
      ".es-text-shortener-container"
    containers.forEach((container, index) => {
      const text = container.querySelector(".es-text-shortener");
      if (!text) return;
      if (!text.id) {
        text.id = `elfsight-short-text-${index}-${Date.now()}`;
  function syncState(root) {
    containers.forEach((container) => {
      const button = container.querySelector(
        ".es-text-shortener-control"
      if (!button || !text || !text.id) return;
      button.setAttribute("aria-controls", text.id);
      const isExpanded = button.classList.contains(
        "es-text-shortener-control-hide"
      button.setAttribute("aria-expanded", String(isExpanded));
      text.setAttribute("aria-expanded", String(isExpanded));
      text.classList.toggle("expanded", isExpanded);
  function observeRoot(root) {
    ensureIds(root);
    syncState(root);
      ensureIds(root);
      syncState(root);
    observer.observe(root, {
      childList: true,
      subtree: true,
      attributes: true,
      attributeFilter: ["class"],
  const globalObserver = new MutationObserver((mutations) => {
    for (const mutation of mutations) {
      for (const node of mutation.addedNodes) {
        if (node.nodeType !== 1) continue;
        const root =
          node.matches?.(ROOT_SELECTOR)
            ? node
            : node.querySelector?.(ROOT_SELECTOR);
        if (root) {
          observeRoot(root);
  globalObserver.observe(document.body, {
    childList: true,
    subtree: true,
Please try it out and let me know if it helped.
Thanks, that seems to have resolved the issue in Siteimprove.
Awesome, you’re very welcome!
In the meantime, we’d like to invite you to participate in our new contest, where you can win a 3-month extension for your subscription - April Contest: What’s Your Top Widget Feature? Tell us and win 3 MONTHS FREE!:wrapped_gift:
