My LinkedIn Feed has a ton of extra space within the post after the LI header and then after the post if there is an image, this creates a lot of missized posts. It doesnt seem there’s a standard size for any of the display options that adjusts for this. I prefer to use carousel and have every post nice and clean without a ton of extra white space. Any CSS options or others experiencing this?
Hello there, @Professor_Z ![]()
Could you please send me a link to the page, where your widget is installed? I’ll be happy to check it for you ![]()
