In my phone the linkedin post is not visible how to add css for particular screen
Hello there, @Prashant_R_Dalai and welcome to the Community :wave:
I am afraid I don’t quite understand your idea. Could you please describe it in more detail?
iN THIS BELOW SCREENSHOT SEE MY LINKEDIN FEED IS NOT VISIBLE IN MOBILE DEVICE SO I JUST WANT THIS TO BE SHOWN PERFECTLY LIKE IN DESKTOP
Thanks!
Due to the peculiarities of Google Sites platform, all elements of apps are being converted into iframe format, which causes incorrect displaying. I am terribly sorry about it!
Iframe calculates the height of the block on mobile based on its size on the desktop. So, to make the widget look good on mobile, you need to stretch the widget in its height on the desktop.
I also need to inform you that an empty space might appear on the desktop below the widget, but it is the only workaround we can suggest in this case.
Please let me know if this clears things up or if you have any questions left :slightly_smiling_face:
