Share your use case and provide as many details to support your idea as possible:
It would be nice to integrate this with WordPress. Now given that there are many WordPress themes, I think it should be a plugin, I also think a custom integration where the Restaurant Menu dashboard can be integrated with a theme’s dashboard, not the WordPress backend dashboard. The reason is so that the restaurant owners or personnel can log into 1 area to edit their theme AND edit there food menu.
@user2349 thank you very much for the detailed explanation!
I guess having the widget integrated to the theme would be an amazing solution, but to be honest I’m not sure that we can do it. Anyways, I hope our devs will think over your suggestion and maybe will find a way to make it happen. I’ll make sure to keep you updated if any changes ![]()
Many thanks for your help, it means a lot! ![]()
Thank you. Let’s wait and see what they say.
