Widget wont display 4 columns on one group
  • Issue description: Widget is set to 4 columns. Displayes 4 Y videos in one group. The tehr group only displays 3 videos. 4th video is published, in the playlist. All settings are correctt
  • Link to the page with the widget in question: Start Here — Rebel Brown
  • Ideas anyone?
Also. Is here a way to get rid of all the white space/line returns below the block?
Hello there, @user39497 :waving_hand:
The 4th video didn’t show up because of the cache. Our widget uses a cache system to make everything load faster and reduce the server load. So the feed is updated every 24 hours.
Here’s an article that touches on this topic: Why my YouTube Gallery doesn’t update.
If it’s been more than 24 hours and the video still didn’t show up, please let us know. We’ll be happy to check things :slightly_smiling_face:
The extra padding below the widget appears because of the Fluid Engine editor used on Squarespace websites. I’ve tried to fix it using our standard CSS solution, but it didn’t work for some reason.
I’ve passed it on to the devs and we’ll report back once the solution is ready!
I cleared the cache ( deleted widget, logged off , logged on and created a new widget with differen name.) That didn’t get the 4th video to load either. Cache hangs on eh? I.m a tech consultant FYI Also reposted the YT video to try to force a reset Originally posted two vids at once to same playlist. I genned the widget for the first time right after that. Ignored the second video but grabbed the other 3 in he PL. Gotta love low tech right? I tried CSS as well on botttom. Same result. THANKS for the reply and Ill let you know after 24 hours.
Hi @user39497, it’s Irene stepping in to help while Max is enjoying his well-deserved vacation :person_surfing:
That said, thanks for the details and for testing all the different scenarios! I appreciate you taking the time to investigate this from your side as well :smiling_face:
Regarding the extra white space below the YouTube Gallery widget, our developers prepared a CSS solution that should help with removing it:
.global-styles,
.fluid-engine:has(.elfsight-app-c0242503-6fca-44dc-b513-941eb12c6680) {
  grid-template-rows: unset !important;
It needs to be placed in the Appearance → Custom CSS section of your widget.
Before adding this CSS, please move the widget into a separate section in your Squarespace editor. Otherwise, the change may affect the layout of the elements placed above the widget.
Please try this and let me know how it works on your side :slight_smile:
