Personally, we are looking for a table that is mobile-responsive, has column headers, allows column sorting, and can expand/collapse groups of rows or columns similar to FAQ widget.
Many thanks for your comment, @SOPFC!
All the info you share is super important, so your help is very much appreciated
Create a table plugin that would allow a table of data on a site.
Welcome to the Community @Dave_Witzel
We already have a similar request in the Wishlist. Iāve moved your comment to the dedicated thread, where weāll keep you abreast of any changes.
In the meantime, it would be great if you could share your vision of this app. What options are must have? How are you going to use it?
Any additional info would be highly appreciated
Table widget Wishlistā¦
Mobile-responsive
Header
Allow to column sorting
Data sync with google sheets integration, - Automatically data pulled from google sheet to the table
Search option
Customize table style, table color, row/column, table background, text, cells, & more
Merge/Split cells
Custom Filter
Conditional Format
Thanks a bunch for such a detailed feedback @DOMINICANCOD!
Could you just elaborate on the Column sorting and Conditional format options? It would be much helpful if you could describe how these features should work in our app
Column Sorting = to arrange data in a specific order withing a column or multiple column
Example :
Ascending Sort (A to Z or Smallest to Largest)
Descending Sort to A or Largest to Smallest)
Custom Sorting Additionally, sorting can be based on formatting, including cell color, font color, or icon set
Conditional Format option:
Example like highlighting based on a cell value
Got it, thank you so much!
I agree that all the mentioned features are really important and, hopefully, our devs will try to consider them when working on the app.
All the updates will be posted in this topic
I need a table widget asap too.
Hi @Darius
A huge thank you for sharing your feedback!
This year, weāre committed to developing new apps and will be prioritizing them according to the votes they gather. Iāll make sure to keep you informed with any news from our developers right here in this thread
Meanwhile, weād love to hear your thoughts about the Tables app. What functionalities are must-have for this widget? How do you plan to use it? Do you have any specific design preferences?
PROD-copy-2024-04
We would love a table app to be able to list our product specifications on our trailers. We have has to use another platfrom in the meantime but we donāt like it. Hereās what it looks like currently: https://delcotrailers.com/dump scroll down to specs. Hereās the table on our competitors site: 72" Tandem Axle Dump Trailer (D3) | PJ Trailers
Hi there @user9125
Thank-you so much for sharing your examples!
Do I understand right that youād like to have a table widget similar to your competitorās version (with an option to switch tables)?
