When closing floating badge, display it after the page reload
Hi,
As mentioned by you once the widget is closed then it will show again after 24 hours only. We have a website with multiple locations and have used this widget. If a user closes the widget for some reason then still it should show the widget after the page refresh. Currently, that is missing so if I close the widget by mistake then I don’t have any option other than wait for 24 hours to see this.
Can you please let me know how can we overcome this problem?
Thanks
Mohit
@Weekend_Feels I’ve talked to our devs and they’ll try to help you with it.
I see that you have 7 widgets. Do I understand correctly that you’d like to apply this change to each one?
Was this ever resolved?
A closed widget does not reappear when the page is reloaded or a new page is opened.
Yep, here is a solution - Reviews: How to always display floating badge even if it was closed.
Please try it out and let me know if it worked for you :wink:
