Your proposal of whataspp is arriving to be “old” compared to others with bot or IA.
It would be great to upgrade it in IA ![]()
Hi there @Julien3 ![]()
It’s really great to see you on our forum, I hope you will find this space!
Do I understand correctly that you’d like to add a chatbot to the WhatsApp Chat app? It would be awesome if you could describe your use case in more detail ![]()
Hello Max,
If possible before sending the whatapp message, i would like a bot who send at the final to one real person.
Ex one if the custumer ask simple questions, that the bpot can already answer. Ex are you open monday ? Where is your location ? what time is opening the restaurant…
=> configure some questions => then when the bot can not respond => to real person.
IA too can help : ex what will be the weather in guadeloupe in mars ?
Julien
I got your point!
I’m not sure that we’ll be able to release such a complex use case, but we’ll try to consider your idea in our future updates ![]()
maybe it can be linked to ai so that it can send a simple message to their whatsapp, just to see if they reply and figure out which leads are good
Hi there, @Ahmad_Hafez ![]()
Your idea makes sense, and we’ll have it in mind! Thanks a ton for your feedback ![]()
you did a great work
With other providers I have found that if you use AI and WhatsApp as a chatbot you cannot message manually anymore on your phone.
Don’t know if this is true but it would be great to have both, if it is not a limitation set by the WhatsApp API
Hi there, @Darius ![]()
Thank you for the feedback!
We’re currently considering adding an option to switch to different channels, like WhatsApp, for our AI Chatbot app - Move from AI to human interaction
If you’d like to see this feature become available, please give this idea an upvote and share your thoughts by answering the questions in the highlighted comment:
Your feedback is really important to us ![]()
