I turn on the notification in the whatsapp app. I notice that Google index this (1 message) and now that affects my google ranking. The effect is nice in the tab, but it may NOT be indexed by google. I have now turned it off on all my sites but can you fix that?
A website (wordpress) where that works well on is from a competitor of mine: https://www. 321klik. nl there when you go to another tab you see the text change as well. Perhaps you can learn how they do it technically.
Other thing, it slows down the pageload, is there something that the Whatsapp is loading after a few seconds?
Hi there @Alexander7 and welcome to Elfsight family
Could you please specify which tool you are using to check the Google ranking of your website? Also, the screenshots of the results with this feature enabled/disabled would be much helpful. I’ll be happy to check if anything can be done
As for the page loading speed, we have a way of improving the performance.
You are very welcome to reinstall your widget by using some kind of lazy loading. It means that the widget will appear on the page only after the visitor interacts with the page, at least move the cursor.
To make it work, you need to add a data-elfsight-app-lazy attribute to the widget installation code. Here’s what the installation code will look like:
@Alexander7 Oh, my bad. I am so sorry for missing that!
I’ll double-check with the devs if there is a way to improve the loading speed of the page and will get back to you
As for the second issue, I got what you mean.
In order to change your title in Google Search, you can either wait for Google to reindex the page or you can request earlier reindexation following the steps from Google documentation - Ask Google to recrawl your URLs. This should resolve the issue.
Keep in mind that reindexation may take from a couple of days to a couple of weeks.
Ask the developers to also prevent the message from being indexed by Google. I have turned it off now. It is possible, as I already wrote in my first message.
So 2 questions:
Lazyload for performance or something else. 2) Prevent the “message” text from the tab from being indexed by Google.
Please look at this site: https://www.321klik.nl/ u can see if u go to an other TAB there is a dutch message. That TAB message is NOT index bij google, so technical it is possible. Maybe the fevs can learn how the do that.
