Just realized today that the weather widget is now displaying the temperature in fahrenheit and not Celsius
We are based in Canada so it’s strictly important to use the correct measurement for our location, as we are proudly Canadian owned and operated, and thus we absolutely should not be displaying temperature readings in Fahrenheit.
I did not change any settings for this to happen, and when checking the widget, I don’t see an option to change it to Celsius.
Yep, currently, the temperature unit depends on the language selected on the Settings tab. For example, if you’re using English (US), the widget will show the temperature in Fahrenheit, since it’s a stadard unit there.
Celsius is used in Canada, that’s why switching the language resolved the issue.
I hope this clears things up.
If you have any questions left, we’ll be more than happy to help
