Earlier there was an option to change the temperature unit to Celsius (°C). Now it is not there. Requesting to please bring back. Thank you! ![]()
@BTEA I think this is a great idea. The °C option will help a lot of people. Also, could we make it so that depending on where they are accessing the website, it would make it a lot more better. Also, if there’s a button on the widget on the website, then people would be able to change to their prefrence.
Hi there, @BTEA and welcome to the Community ![]()
Currently, the temperature unit depends on the language selected on the Settings tab.
At the moment, you’re using Englih (US). Since Fahrenheit is a standard temperature unit for the US, it’s displayed in your widget:
However, if you switch the language to English (UK), the temperature unit will be Celcius:
Please let me know if this clears things up or if you have any further questions ![]()
Thank you and appreciate your prompt reply.
You’re always welcome ![]()
