Volume control in the setting
Volume should be controled in the settings as well by the individual as an option It is very important when adding background music to a site.
Original Votes: 2
Quick update: this feature is in the works now :slight_smile:
Highly likely we will have it released in Q1 already!
It would be nice if I could publish the background music widget in a low level sound, then increase the sound level on the website, if necessary. I would like to use an AI assistant with voice as well and it would have a conflict with the background music if it starts loud.
Thank you.
Hi @Simina_Ioana_Dimcea :wave:
This idea is great indeed and I am glad to tell you that our devs are working on this functionality. I’ve moved your request to the dedicated topic, so that you could follow the latest updates here :slightly_smiling_face:
Thanks a bunch for sharing your thoughts and welcome to Elfsight Community :heart:
Thanks a lot. It would be helpful to have the AI assistant talking and some music in the background for my website. :heart:
Have a great day!
În mar., 29 aug. 2023 la 14:02, Max via Elfsight Community <notifications@elfsight.discoursemail.com> a scris:
Do I understand that you’d like AI assistant to be included into Background Music widget? Or you mean a third-party separate app?
The AI assistant is a third-party app.
I only want to publish the widget with the music volume at the lowest limit so that the AI’s voice can be easily heard and understood.
I am showing you this example: www.timetorefokus. com
Thank you.
În mar., 29 aug. 2023 la 14:55, Max via Elfsight Community <notifications@elfsight.discoursemail.com> a scris:
Hey everyone!
The Volume by Default setting is already here :rocket:
Test it out and share your experience with us :wink:
