Using AI Chatbot to Improve Website | Elfsight AI Studio
Currently, Elfsight’s AI Chatbot widget is over the top. It is truly helping our site visitors and customers.
Based on the above, is it possible to install it in the backend and train it to help improve our website? Examples: Content creation, check existing content for proper syntax, check for inconsistencies, check for broken links, check for suspicious code, perform an SEO audit, etc.
If currently not possible, well, what are you waiting for? :slight_smile: This would be huge. The possibilities would be unlimited. You can call the new widget: Elfsight AI Studio!
AI is moving faster than the speed of business. There is no turning back.
Thoughts?
Hey there, @Petar_Dietrich :waving_hand:
This idea sounds interesting, but, at the moment, there is no way to modify the AI Chatbot for this use case.
As for creating the new AI Studio app, I am afraid, we won’t be able to release such an app. The thing is that our apps are designed to be used in the frontend, and this app is supposed to be used internally, which goes beyond our general widget concept.
I hope this clarifies things.
Anyway, thanks a lot for sharing your thoughts with us and collaboration, we truly appreciate it :slightly_smiling_face:
Hi @Max, Bummer. Thank you for the explanation. Enjoy your day!
