Twitter Feed display issue
Yay! Thanks for this! How long is it expected to have Posts load (seems to only do recent replies instantly) on new widgets?
Hi there, @Kate4 :wave:
Once you add the source, the posts from your account should be pulled right away. After that, they’ll be updated every 48 hours.
However, I’ve checked your widget and see that the oldest posts haven’t been pulled. I’ve forwarded this issue to the devs and will update you once I have any news :slightly_smiling_face:
Thanks, Max! It seemed to only pull a couple random replies and no posts. I would love to push this widget for my audience on X, I already have a few people that I know would love to use this widget for their websites.
Thank you for waiting, and apologies for the confusion caused!
I’ve talked to the devs and they’ve said that the widget initially retrieves about 20 latest posts (though this number can be lower, as you’ve experienced). After the initial connection, new tweets are added with each feed update, which occurs every 48 hours.
I’ve also checked your widget and can confirm that it has successfully pulled other posts. Could you please check your widget and let me know if everything is fine now?
