Issue description:
myC hatbod isnt showinf after several fixings of the Code. what could be the issue
Issue description:
Hi there, @Philip_Maviti and welcome to the Community ![]()
I’ve just checked your website and see that the widget is displayed now:
Could you please confirm if everything is fine on your end at the moment?
Check https://www.nextbestflight.com Nothing no Icon no chat Hello nothing
Yes, I took the screenshot directly from this website. As you can see, the widget is displaying correctly on my end.
Initially, you’ll see the Quick Input button, along with the greeting and suggested questions above it, just as configured in your widget settings:
Widget editor:
Website:
Once you send a message or click on one of the suggested questions, the chat window will open:
Could you please check it again?
If you don’t see the widget at all, please try opening your website in an incognito window. If that doesn’t help, could you please send me a screenshot of what you’re seeing on your end so I can look into this further?
Seen it Max. God bless u. Input your email n see how it behaves.vI kindly request for feedback. Are you in Europe or?
Ciao Philip
Glad to hear that, Philip! ![]()
While looking into your case, we also checked how the widget works, and everything seemed to be working as expected on our end. However, if you notice anything unusual or have any specific questions, please don’t hesitate to reach out. We’ll be happy to help!
And yes, our headquarters are in Andorra, so we’re based in Europe.
Thanks
