Nam
(Nam)
- Issue description:
AI Chatbot Problem
When a user speaks to the AI Chatbot, it stays thinking indefinitely. It doesn’t respond at all.
Is there any way to reset it so it works properly again?
Max
3
Hi there, @Nam
I apologize for all the inconvenience caused by this!
There were some technical issues on our end, but now everything is fixed, and the widget should be working fine.
Please check your widget and let me know if the issue is resolved
Nam
(Nam)
4
Solved! Thanks a million.
Max
5
Great, you’re welcome!
In the meantime, we’d like to invite you to join our new challenge, where you can win 3 FREE months for your subscription. Check the details and participate
- March Challenge: Share your results with Elfsight & win 3 FREE months!
