Tripadvisor widget original language review
  • hi i have a problem with the widget for tripadvisor, reviews are translated in english since it’s the .com source but i want the reviews in there original language. how can i do that ?
  • i(m on the free plan for now, going to upgrade soon
Hi there and welcome to the Community, @Simon_Guillo :waving_hand:
Could you please send me a link to the page with the reviews, where they are in their original language? I’ll be happy to check it for you :slightly_smiling_face:
Hi max, here is the tripadvisor link https://www.tripadvisor.com/Attraction_Review-g150812-d17821661-Reviews-John_Diving-Playa_del_Carmen_Yucatan_Peninsula.html the reviews are automatically translated in english but exist in original language
The thing is that the language of the reviews depends on the domain used in the source URL. Domains .com show the reviews in English. I see that most reviews are in French and if you replace .com with .fr, the widget will display the reviews in French:
Please check it out and let me know if it worked for you :wink:
when i try the french link it doesn’t fetch any data unfortunately but do work with the .com
