Could the translation in portuguese “Escreva uma crítica” be changed to “Escreva um depoimento” please???
Crítica its not a good word in portuguese.
Hi @Kihara, thanks a lot for pointing this out!
We will make sure to change the phrase, thank you for providing the correct one ![]()
Meanwhile, you’re welcome to edit all the phrases in your widget Settings tab → Language:
Please let me know if it helps ![]()
@Kihara, I’m coming with great news!
We’ve corrected the mistake in the translation, so everything displays fine now ![]()
Thanks a lot for your help!
Thank you!!!
