Helga
July 5, 2023, 7:55am
3
Hi @user3386 and welcome to the community!
I’m very sorry about this issue, but we’re already working on this! I’ll get back to you once everything’s back to normal
Helga
July 6, 2023, 6:24am
4
Hi @user3386 , many thanks for waiting!
The issue is fixed, could you please check your widget and let me know if everything’s fine?
Hello Helga, we currently have the same issue. Could you perhaps take a look at our situation as well? Regards, Rolf
Helga
August 14, 2023, 8:29am
7
Hi @Rolf_Heinrichs , my apologies for the delay and for the issue!
The good news is that everything’s fixed and back to normal, could you please check your widgets and let me know if everything’s fine?
Hi Helga,
I have the same problem on my website : https://pavagerobillard.com/
The reviews are originally in French but appear in English on the website.
Thanks,
Nicolas
Max
February 28, 2024, 10:14am
9
Hi @Nicolas_Moncion and welcome to the Community
Please let me step in for Helga.
I’ve checked your website and see that you are using different Google Reviews widget, not from Elfsight:
If you are experiencing issues with our app as well, please specify your widget ID and I’ll gladly check things for you
