Track Slider and input fields
Hi, we want to track any slider changes or direct number entires in our calculator form in google analytics. Can you state the custom code for this? Thanks!
Hi there, @Marcel_Grosskopff :wave:
Unfortunately, there is no way to track the interactions with the Slider field at the moment. However, this is a cool idea and I’ve moved it to the Wishlist.
If more users upvote this request, we’ll try to think about it in the future :slightly_smiling_face:
Hi Max! Thanks for the quick answer - how about the input fields for the values? or the first button to start the form from the calculator (not the send the form button)?
It’s impossible to track the input fields as well. However, we can create a GA code for tracking clicks on the button opening the form.
I’ve forwarded your request to the devs and will let you know once the solution is ready :slightly_smiling_face:
I am happy to inform you that our developers have prepared a Google Analytics code for you to track clicks on the button. Please add this part of the code to your website <head>:
gtag('js', new Date());
gtag('config', 'G-ID');
function sendEvent(config) {
	if (typeof ga !== 'undefined') {
		ga('send', 'event', {
			eventAction: config.action,
			eventLabel: config.label,
			event_label: config.label,
  let i = 0;
  const check = () => {
    if (component) {
      res(component);
    } else if (i !== 50) {
      setTimeout(check, 100);
      i++;
  check();
waitForElement('[class*="cta__Container-sc"]').then(button => {
  button.addEventListener('click', () => {
    sendEvent({
      action: 'click',
      category: 'Elfsight Calculator Widget',
      label: 'Click CTA Button'
Try it out and let me know if it worked :slightly_smiling_face:
I know we can see how many people viewed the calculator but I would like to know how many interacted with the calculator. That will help me understand if it is a valuable resource on the page.
Hi there, @user18882 and welcome to the Community :waving_hand:
Do I get it right that you’d like to track how many people moved slider fields in the calculator to change their values?
Yes, so I can see if people are leveraging it.
Got you!
We already have a similar idea on the Wishlist. I’ve moved your comment to the related thread, where we’ll keep you in the loop :slightly_smiling_face:
