Testimonials slider - mobile setup
  • Issue description:
    in the testimonials slider app , how do i make the header size smaller on mobile ?
    and how do i remove the container width adjustment thing below the user comment ? also , on mobile
Hi there, @Aviram_Levy :wave:
You can adjust the title size on mobile, using this code in the Custom CSS field on the Style tab of your widget’s settings:
@media(max-width: 500px) {
[class*="WidgetTitle__Header-sc"] {
  font-size: 25px;
As for the scrollbar, they appear because the Wix platform is built on iframes. To remove these scrollbars, please reinstall your widget avoiding iframes following the steps described in this article - Installing Elfsight widget on Wix avoiding iFrame - Elfsight Help Center.
Give it a try and let me know if it helped :wink:
