Hide scrollbar on carousel
Ability to hide scrollbar on carousel mode
@Emory_Clark If I got you right, your widget is installed on Wix website.
The Wix platform is built on iframes, that’s why the widget gets the scrollbars. To remove it, you should reinstall the widget avoiding iframes - Installing Elfsight widget on Wix avoiding iFrame.
Please follow the steps described in the article and let me know if it helped :slightly_smiling_face:
