Issue description: Hi, I am having an issue with the Store Locator Widget. When I search using a zip code, it only works for some zip codes and not others. Even when I type a specific zip code that I know a store is located within, it doesn’t show up… but it does show up when I type the suburb instead. Eg the suburb Baccus Marsh. It only seems to happen to some suburbs in Victoria and New South Wales. Any ideas why?!
Link to the page with the widget in question: http://www.theverybest.com.au
Happy to see you on our forum! Welcome, @user28310 ![]()
The search in our Store Locator app uses Google’s API, which has issues with handling 4-digit zip codes.
To get around this, we also send the current map boundaries when searching.
So, if you’re searching for that zip code while you’re within the southern Australia region, the zip code search will work:
Please let me know if this explains things or if you have any questions left ![]()
